configure ospfv3 area add range
configure ospfv3 area area_identifier add range ipv6netmask [advertise | noadvertise] [inter-prefix | nssa]
Description
Configures a range of IPv6 addresses in an OSPFv3 area to be aggregated.
Syntax Description
area_identifier Specifies an OSPFv3 area, a four-byte, dotted decimal number.
ipv6netmask Specifies an IPv6 address / prefix length.
advertise Specifies to advertise the aggregated range of IPv6 addresses.
noadvert Specifies not to advertise the aggregated range of IPv6 addresses.
inter-prefix Specifies aggregate, inter-area-prefix LSAs.
nssa NSSA LSAs.
Default
No OSPFv3 inter-area-prefix LSAs are configured.
Usage Guidelines
If advertised, the aggregated IPv6 range is exported as a single LSA by the ABR.
The following command is used to summarize a certain range of IPv6 addresses within an area and export them out as a single address to area 0.0.0.1:
configure ospfv3 area 0.0.0.1 add range 2aaa:456:3ffe::/64 advertise inter-prefix
Platform Availability
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
